Sink P Trap In The Basement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2010, 07:20 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
sink p trap in the basement.
Remodeling a kitchen, and the old setup they had the drain for the sink running through the cabinets beside the sink into the wall (about 5') to the vent stack. Which completely sucked. I had a plumber today tell me that since the sink is 5' or less from the main stack, that he can extend the tailpipe from the sink 4' down into the basement and put the p trap down there and then run it over to the vent/stack and no new vent would be required???
ryanh is offline   Reply With Quote
Old 09-28-2010, 07:34 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 674
Maximum length of a tailpiece is 24" so it can't go through the floor.
He's right about 5ft trap arm though. Why not just pipe it in the wall under the windowbehind the cabinet?
Old 09-28-2010, 08:16 PM   #3
ryanh's Avatar
Rewards Points: 154
I suggested that, but he said not needed, he could just drop the p trap to the basement and be done with it.
What is the 5ft trap arm rule? If the sink is less than 5' from the vent stack it doesn't need a vent source, you can just run a 2" drain to the stack??
Old 09-28-2010, 08:37 PM   #4
Plumber
Rewards Points: 674
ryanh, I need to back track a bit. 5ft trap arm applies to 2" pipe only. If its 1.5" then the arm can be 3.5' max length.
Every trap needs a vent. Simply put, they help traps drain properly. Its like a gas can that that doesn't pour right until you flip the breather plug open.
The lengths are determined by the slope of the drain line and the pipe diameter.
Realize too that codes vary across the country so he may be correct for your area, but I doubt it. A sink tailpiece is a great place for bacteria and such to accumulate. I would want it as short as possible.
Old 09-28-2010, 09:51 PM   #5
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
GET ANOTHER PLUMBER THAT KNOWS PLUMBING
CODE ! ! !
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 09-29-2010, 10:57 AM   #6
ryanh's Avatar
Rewards Points: 154
Ok. So the trap arm rule pretty much says that if your 5' or less away from the ventstack you can you use 2.0" pipe. Meaning you don't need to add a new stack. Ok gotcha i get it
Old 09-29-2010, 01:06 PM   #7
Chicago, IL
Michael Thomas's Avatar
As others have noted P2706.2 limits tailpiece lenght (except for clothes washer standpipes) to 24".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-30-2010, 10:27 PM   #8
ryanh's Avatar
Rewards Points: 154
Thanks for the notes guy, This guy just a crackhead plumber. I will find someone else, he also swears on mike holmes that any fixture without 5' of the trap when using a 2" line doesn't need a vent lol
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 12:14 PM
Adding a utility sink in the basement - draining question sbazzle Plumbing 3 04-24-2010 05:59 PM
Sink gasping water Filbee Plumbing 7 10-23-2009 10:36 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
