Sink Leaking Between Tailpiece And Slip Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2013, 01:17 PM   #1
Sink leaking between tailpiece and slip joint
Hello,
Need some help here. The previous owner cut the sinks tailpiece down to about 1" so a drawer would close. A 90 degree slip joint and pipe is then used to connect to the P trap. If you fill the sink and then release the stopper, water will leak where the tailpiece and 90 degree fitting meet. This also happens if you dump a bucket of water into the sink. I assume this is because the 1 1/4 pipe with a 90 degree bend can't handle the amount of water and it backs up out of the slip joint.
I am thinking of doing one of the following: 1. replace all of the slip joints with glued PVC until I get to the P trap. 2. Buying a new tailpiece and replacing the drawers so the pipe will fit. I would prefer option 1, am I missing something?
Thanks,
Ben
Bcoleman6 is offline   Reply With Quote
Old 05-31-2013, 01:21 PM   #2
pictures would make it a lot clearer
Old 05-31-2013, 01:23 PM   #3
Rewards Points: 14,278
Post a picture so we can see what your seeing.
I've often had to alter the drawer to make room for the drain.
Old 05-31-2013, 01:57 PM   #4
Will do. I am at work right now, but will post pictures in a few hours.
Old 05-31-2013, 02:27 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 900
have you tried replacing the slip joint washers?
You will have to upsize to 1.5" if you glue it- unless you can find 1.25" fittings.
Is the stub at the wall 1.5" or 1.25"
Old 05-31-2013, 02:43 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
The washers are installed backwards (beveled ones) all the time.
I would leave it as a slip joint for easier servicing. It is a proven joint and works plenty well when done right.
Old 05-31-2013, 03:46 PM   #7
Rewards Points: 2,104
The washers need to go towards the threads. The Nut must be very tight. One turn past hand tight with a channel lock pliers
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Caulk underneath sink drain/plate? doogie88 Plumbing 14 04-16-2009 07:18 AM
