Sink Installation - Please Help Again! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-10-2007, 05:26 PM   #1
Question
Sink Installation - Please help again!
Hi everyone! Earlier I made a thread about this sink / countertop. I am just wondering now though, if this is possible to actually get installed myself without a plumber? I have taken some pictures as you guys can see, my new sink value doesn't align properly with the pipe below it. Does anyone of you guys know how to remedy this? Thank you in advance!
iOsiris is offline   Reply With Quote
Old 07-10-2007, 05:55 PM   #2
Rewards Points: 150
Cut out the trap and replace with a trap that is articulated which makes for easier alignment. It's less than $10 in parts and 1/2 hour worth of work... you can do it!
slakker is offline   Reply With Quote
Old 07-10-2007, 06:29 PM   #3
Originally Posted by iOsiris View Post
... my new sink value doesn't align properly with the pipe below it.
Are you refering to the drain line or the water lines to the faucet?
redline is offline   Reply With Quote
Old 07-10-2007, 06:32 PM   #4
The drainline, the black pipe and the drain from the sink
Old 07-10-2007, 06:54 PM   #5
If you cut the black pipe just after the trap and then install a new p-trap assembly with compression nuts then that will give you plenty of adjustments to connect to the sink drain. An extension tube will bring up to the sink drain.
Old 07-10-2007, 11:16 PM   #6
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
I would add two 45's to the riser and stay with the larger pipe you have than drop it down to 1 1/2" od tubular.
MechanicalDVR is offline   Reply With Quote
Old 07-17-2007, 05:39 PM   #7
heh guys thanks for the help!
Old 07-17-2007, 05:58 PM   #8
How did you finish it off?
Any photos?
Old 08-06-2007, 12:55 AM   #9
My first plumbing job -_-
Old 08-06-2007, 09:21 PM   #10
Rewards Points: 81
Gotta love the depot.............another one is born.
Internet Electrical Critic
Trump Enthusiast
Old 08-07-2007, 08:30 AM   #11
Mechanical Engineer
Rewards Points: 125
Exclamation
I take it that you don't think this is the best way to do this. I would agree. Looks like the drain pipe is cocked at an angle.
gshock is offline   Reply With Quote
Old 08-07-2007, 10:02 AM   #12
Rewards Points: 264
Look at it this way, they could have paid a plummer and gotten the same results. - lol
Jeekinz is offline   Reply With Quote
Old 08-07-2007, 10:42 AM   #13
Mechanical Engineer
Rewards Points: 125
Lightbulb
... Or worse. At least he asked questions.
Old 08-07-2007, 05:58 PM   #14
Lol, yeah the pipe was cut short :X Here my second plumb job for your viewing pleasure.. or pain. You decide!
Old 08-07-2007, 10:01 PM   #15
fierysun's Avatar
Good job on the second plumbing job. :D
Trying to keep all my fingers and toes
Personal site
fierysun is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Double sink drainage installation JeffBPaarsa Plumbing 2 11-23-2006 10:08 AM
