-   -   Sink install (http://www.diychatroom.com/f7/sink-install-40709/)
ponch37300 03-19-2009 08:52 PM
Sink install
I'm setting a new sink, it's granite. It's an above mount that will be sitting on a granite tiled counter top. Should I use plumbers putty or caulk under or around the sink? I would think I need to caulk around the sink. Also when I install the strainer and garbage disposal should I use plumbers putty under the lip? Thanks for advice on this.
kenmac 03-19-2009 08:57 PM
I like silicone myself
Rivethead 03-20-2009 04:13 AM
I'd use the putty in a thick continuous rope around the underside outer edge - don't skimp on it. You shouldn't have to caulk it. The same with the strainers - tighten them then run hot water and snug them down another quarter to half turn.
SDC 03-20-2009 07:08 AM
X2 :thumbsup:
Plumber101 03-20-2009 07:40 AM
I have seen putty stain items.
Use clear silicone and if you need to find a color that matches.
I hardly use putty on anything. Ask your granite supplier. Many companies will void any warranty (if any) if putty is used
ponch37300 03-20-2009 08:01 AM
Thanks guys. Think I'm going to use putty for the strainers and silicone for the sink unless someone says either is a bad idea to do.
