Sink Hose Removal-How? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2013, 10:55 PM   #1
Rewards Points: 666
I am attempting to remove a pull out kitchen faucet hose from below the sink, with limited success due to very limited space access. Attached is the picture of the new hose end that has to be removed from below the sink. How do you remove this type of hose end? Unscrew it, turn and then it releases? Also, what is the black clip that is around the hose?
Sink Hose Removal-How?-clip.jpg   Sink Hose Removal-How?-delta.jpg   Sink Hose Removal-How?-hose.jpg
kennykenny is offline   Reply With Quote
Old 07-23-2013, 06:54 AM   #2
DIY staff
Rewards Points: 7,174
that is a simple push on connection---To remove it--push up ,gently--remove the plastic retainer clip and the pull off the hose.
Old 07-23-2013, 08:12 AM   #3
Rewards Points: 666
Simple if I could reach the end of the hose-ha! What is the purpose of the clip?
Old 07-23-2013, 09:20 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
The hoses are a type of push fit coupling method.
Without the clip the hose joint will separate when the faucet is turned on- you must install the clip.
Old 07-23-2013, 11:25 AM   #5
Rewards Points: 666
So just remove the clip and then push up on the hose and pull back down until the hose comes apart(or do you have to turn as well)? Just attempting to figure out due to the lack of space to even grab the hose. Thanks!
Old 07-23-2013, 11:36 AM   #6
Rewards Points: 13,300
You do know you can remove the whole faucet to make it easier to work on, right?
Old 07-23-2013, 04:20 PM   #7
Rewards Points: 666
Removing the whole faucet would force me to have to have great access to the underside.
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 04:05 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
sink removal dumhomeowner Plumbing 4 07-08-2008 12:38 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
