Old 03-23-2009, 11:33 PM   #1
Sink holes are larger than o'ring on faucet
The hole dimensions in the Porcher sink are too big for the o'ring and mounting plate assembly of the Hansgrohe faucet.
The holes in the sink are 1 3/8" across. The o'ring does not set ON the porcelain, it is almost fully visible in the hole. The brass of the mounting plate sets on the porcelain directly.
This will cause leaks. Does anyone have ideas? Are the secondary o'ring sets available?
Hansgrohe interaktiv metro faucet 4" or 8" widespread lav
Porcher Calla II sink
jaymalea is offline   Reply With Quote
Old 03-23-2009, 11:43 PM   #2
HVAC / Plumbing
If it's too small.....You Might try HD or plumbing supply for the correct size
kenmac is offline   Reply With Quote
Old 03-24-2009, 09:52 AM   #3
Hansgrohe is weird. They say the valve holes should be 1 1/4" but the spout hole can be 1 3/8". You won't find a pre-drilled sink like that. Since the escutcheon is 2 1/8" wide, just use a rope of putty or a bead of silicone instead of the o-ring.
porchmonkey is offline   Reply With Quote
Tags
hansgrohe, o-ring, porcher
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
How do I enlarge the vanity faucet holes RippySkippy General Discussion 2 09-16-2008 08:58 AM
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 12:45 PM
Vessel Sink height and faucet height KCourtland Plumbing 1 09-30-2007 08:39 PM
