Sink Gurgling On Toilet Flush - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2012, 07:13 PM   #1
Sink Gurgling on Toilet Flush
We are in the process of finishing my basement. We had plumbing installed - the water was ran with Pex tubing and a sewer ejector pump was installed. Closest to the pump is a stall shower, then there is a toilet, then our bathroom sink, furthest down the line is a kitchen sink. The kitchen sink is not hooked up yet.
The toilet is flushing fine, the shower is draining water just fine...when I flush the toilet there is a gurgling in the sink. It seems as though water is sitting in the bottom of the P Trap once the water stops running, while water is running it is draining just fine.
There are vents on both of the sinks. I do not have a picture of the bathroom vent, but it is the same type of vent as is on the the kitchen sink, which I do have a picture of.
The vent on the bathroom sink is connected to the pipe in this picture, it extends to the ceiling.
I do not know if this is caused by a venting problem and cannot see if they are clogged since they have are behind sheetrock.
Any help or suggestions would be greatly appreciated. Thank you.
PS. I do have a video showing all of the plumbing if that is needed.
seanyb00 is offline   Reply With Quote
Old 10-02-2012, 07:20 PM   #2
Rewards Points: 636
ok 2 things first is the air admintance valve (cheater vent) must be accessible . so after you cut the drywall replace the black spring loaded vent(not legal for what you are using it for) and replace it with a legal no spring a.a.v. and see if that fixes issue
thn use a small cold air grill to cover up a.a.v so it is accessible in future
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
seanyb00 (10-03-2012)
Old 10-03-2012, 03:35 PM   #3
Is this the type of vent I would want?
http://www.ipscorp.com/plumbing/studor/minivent
Or this?
http://www.ipscorp.com/plumbing/studor/redivent
Thanks.
Old 10-03-2012, 10:47 PM   #4
Rewards Points: 636
yes either should work
Need Help with Problem with Laundry sink and toilet alwayslearning Plumbing 22 12-24-2011 11:25 PM
Toilet Won't Flush schraggyj Plumbing 16 07-23-2011 04:22 AM
Toilet won't flush properly yarnpiggie Plumbing 1 03-26-2011 06:43 PM
Commercial toilet vs. Assisted Flush Residential Toilet gatesj1221 Plumbing 3 03-16-2011 12:47 AM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 06:33 PM
