-   -   Sink Gurgling on Toilet Flush (http://www.diychatroom.com/f7/sink-gurgling-toilet-flush-158740/)
seanyb00 10-02-2012 07:13 PM
We are in the process of finishing my basement. We had plumbing installed - the water was ran with Pex tubing and a sewer ejector pump was installed. Closest to the pump is a stall shower, then there is a toilet, then our bathroom sink, furthest down the line is a kitchen sink. The kitchen sink is not hooked up yet.
The toilet is flushing fine, the shower is draining water just fine...when I flush the toilet there is a gurgling in the sink. It seems as though water is sitting in the bottom of the P Trap once the water stops running, while water is running it is draining just fine.
There are vents on both of the sinks. I do not have a picture of the bathroom vent, but it is the same type of vent as is on the the kitchen sink, which I do have a picture of.
http://i169.photobucket.com/albums/u...s/IMG_0145.jpg
The vent on the bathroom sink is connected to the pipe in this picture, it extends to the ceiling.
http://i169.photobucket.com/albums/u...s/IMG_0147.jpg
I do not know if this is caused by a venting problem and cannot see if they are clogged since they have are behind sheetrock.
Any help or suggestions would be greatly appreciated. Thank you.
PS. I do have a video showing all of the plumbing if that is needed.
jaydevries 10-02-2012 07:20 PM
ok 2 things first is the air admintance valve (cheater vent) must be accessible . so after you cut the drywall replace the black spring loaded vent(not legal for what you are using it for) and replace it with a legal no spring a.a.v. and see if that fixes issue
thn use a small cold air grill to cover up a.a.v so it is accessible in future
seanyb00 10-03-2012 03:35 PM
Is this the type of vent I would want?
http://www.ipscorp.com/plumbing/studor/minivent
Or this?
http://www.ipscorp.com/plumbing/studor/redivent
Thanks.
jaydevries 10-03-2012 10:47 PM
yes either should work
