Old 09-29-2012, 05:33 PM   #1
Sink fills with water from dishwasher
Why does my sink (where the DW drains through) fill with cloudy water when my DW is operating?
I bought a new plunger and marked it only for 'sinks' and used that once and it seemed to work for a short time.
Hoping I can do something without paying a plumber.
Also, even tho this happens does it matter if I continue to use the DW?
thanks
Startingover is offline   Reply With Quote
Old 09-29-2012, 05:38 PM   #2
call me E
TheEplumber's Avatar
You have a restricted drain line
Disassemble your trap and make sure its clear. If it still runs slow, you'll need to cable the kitchen drain line. You can rent small power augers
The Following User Says Thank You to TheEplumber For This Useful Post:
Startingover (09-29-2012)
Old 09-29-2012, 05:57 PM   #3
eplumber
thanks, that sounds like something I could do. I've taken the bathrm sink drain apart when jewlery went down it.
When I put it back together should I use some stuff I recently bought, "Plumbers Dope", on the joint?
My bathroom sink just started draining slow so I was going to buy a little auger thing anyway.
Old 09-29-2012, 06:22 PM   #4
call me E
Pipe dope won't hurt but is usually not required for traps. Good alignment when fitting the parts back together is critical though- good luck
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
conversion of portable dishwasher to stationary one grimsbyman Plumbing 14 02-19-2013 08:54 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
No hot water at kitchen sink allwet Plumbing 9 12-02-2009 08:37 AM
Water from sink backs up in stack pipe. droy Plumbing 5 01-24-2008 07:39 PM
