Sink Drain Makes Gurging Sound - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2010, 12:40 PM   #1
sink drain makes gurging sound
In my basement I have a pump in a sewage pit in the ground. I think the vent of this pit is somehow tied to the vent of a sink drain nearby.
The pump runs fine. But everytime when it shuts off after pumping out the waste, I hear a gurging sound out of the sink drain. And sometimes I can even see a little bit of water splashing out of the drain.
I suspect it is a venting problem but I can't open the wall now to see how they are tied together.
The sewage pump has a checkvalve directly above it. It seems that when it shuts off, the waste water falls back onto the checkvalue stop and creates some air pressure into the pit and push through the vent. But that's just my guess and even if it is true how can I fix it?
Any suggestions?
ninghai is offline   Reply With Quote
Old 08-04-2010, 03:30 PM   #2
Owner
LateralConcepts's Avatar
So is the sink drain the lowest point in the house or is there a floor drain nearby also?
Either there's some type of blockage in the main causing a small back-up when the pump discharges (if there's a floor drain nearby and is not effected, this is most likely ruled out)
or
There's a problem with the way the ejection line was tied in.
or
There's a ventilation problem.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Pedestal Sink Drain Meridius Plumbing 9 11-11-2010 01:19 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 11:24 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
