Sink Drain Identification. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2011, 04:30 PM   #1
Sink Drain identification.
Hi All,
I have been fixing my house a bit at a time and am working on the basement 1/2 bathroom. I saw that the drain was covered in corrosion and figured I would replace the entire unit. I already replaced the p-trap so how hard can this one be...
So I bought the parts I needed, opened the cabinet doors to the sink and was staring at the place where a lock nut should be. In place of the lock nut there appears to be a large metal washer snugged up against the rubber washer. I noticed that directly under the metal washer, there appears to be symmetrical dimples (cannot really see it in the picture) all around the drain.
If I twist the drain, the drain hole up top turns with it. I am not sure how to proceed in removing this shy of cutting the drain flush with the metal washer and hoping it comes off.
Any help is greatly appreciated, thanks
RedEagle is offline   Reply With Quote
Old 07-08-2011, 04:41 PM   #2
DIY staff
Rewards Points: 7,174
That's a weird one-----I'd just saw that off carefully with a SawsAll and not even bother trying to figure out that mystery.---Mike---
RedEagle (07-09-2011)
Old 07-09-2011, 10:42 AM   #3
Thanks Mike! I'll take a 'hack' at it and see what happens
Help with sink drain. Steve S Plumbing 10 11-09-2009 01:42 AM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 08:36 PM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 08:36 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
