Sink Drain Height....am I Ok? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 01:50 PM   #1
sink drain height....am I ok?
Long story short I installed my bathroom sink drain at 22" off the finished floor level. Im installing a 31" vanity...do you think I will be ok or am I nixed?
While your here I have a second question.....
for the vent...my options (not including running a new line from my basement through my roof)
1. run a vent line ~25' horizontal (1/4 slope) before tieing into my 2" seconday vent.
2. install a aav valve.
Is option 1 allowed?
comments....
Thanks,
Jesse
oba97 is offline   Reply With Quote
Old 02-28-2012, 06:22 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 994
18 inches off the finished floor 22 may be OK depending on the vanity and or sink you will be using.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-28-2012, 09:34 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We normally go 19 off the rough floor for lavatory drains, but nowadays it seems like everyone is putting in 36" tall vanity cabinets and we end up using tailpiece extensions on everything.
When you say 31" vanity, is that the height of the cabinet? If so, it seems odd. Is it custom?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (02-29-2012)
Old 02-28-2012, 10:51 PM   #4
Rewards Points: 582
alot of plumbers rough in 18-20" off rough floor...seems to work in just about cases.....except custom installs
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-29-2012)
Old 02-29-2012, 06:22 AM   #5
DIY staff
Rewards Points: 7,174
How about those 'vessel sinks'---a mixing bowl mounted on a counter top?
Those always have a lot of tail piece extensions-- I won't be sorry when those go out of fashion--
Old 02-29-2012, 08:59 AM   #6
Doing it myself
Alan's Avatar
I installed a really cool looking vessel about a month and a half ago.
It looked like a wooden bowl, but it was actually a clear glass bowl with wood grain kind of screen printed onto the backside of it.
I like the way they look, but they are not very practical. I Probably wouldn't put most of them in my house.
There is ONE that american standard makes that I would get. It kinda looks like a vessel but it only sits up a couple inches off the countertop. I don't have the money for that kind of junk right now though.
Journeyman Plumber
Old 02-29-2012, 06:35 PM   #7
Rewards Points: 582
don't do that many in my area when I did do a few seem to me drain was around 24" of floor..just guessing though can't remember...
Old 02-29-2012, 07:35 PM   #8
DIY staff
The first one that I installed--the customer turned on the water --and ended up with a wet dress--the water blasted up the bowl and really soaked her---
I turned the shut offs down a bit---
ben's plumbing (02-29-2012)
Old 02-29-2012, 07:41 PM   #9
Doing it myself
Alan's Avatar
The one that i mentioned above had to be something crazy like 27 or 28 to clear the drawers.
Good luck getting any other sink to hook up to that stupid plumbing.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (02-29-2012), oh'mike (02-29-2012)
Old 02-29-2012, 07:53 PM   #10
Homerepairguy's Avatar
Rewards Points: 998
If a family member is a sr. citizen or if a anyone has had back problems, I strongly suggest NOT installing a vessel sink. Using a conventional sink that's recessed below the counter top, it's convenient to prop the upper body using elbows on the the counter top when bending over at the waist to wash the face or rinse the mouth after brushing. It's impossible to do that with a vessel sink that's above counter top level.
Always washed my face by bending forward at the waist without propping my body using my elbows my whole life. One day I pulled my back doing it that way. So now I always prop my upper body using my elbows and forearms on the front ledge of the counter top. That incident is when I realized the disadvantage of vessel sinks.
HRG (who has had occasional back problems for many years)
Homerepairguy is offline   Reply With Quote
Old 02-29-2012, 09:42 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
17-18" is about where I normally aim also
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
ben's plumbing (02-29-2012), oh'mike (03-01-2012)
Old 03-01-2012, 05:57 AM   #12
DIY staff
I was taught to remember the ages of adult hood---
18 for the drain---
21 for the water lines---
Old 03-01-2012, 08:53 AM   #13
hmmmm....I re-measured and I am closer to 21" of the floor. I guess I will just have to set up the sink and see if it's going to work. Man I hope it does!
Old 03-01-2012, 10:20 AM   #14
plummen's Avatar
18 for the drain---
I like that idea,of course ive been holding at 16 years old longer than many of these guys have been alive!
Old 03-02-2012, 07:09 PM   #15
DIY staff
Chances are you are in very good shape--modern vanities tend to be taller that the sinks of old---almost every vanity I install needs an extension,because the drain is to low--
Sink drain leaking, question bergerdude Plumbing 3 03-27-2011 12:43 PM
minimum drain pipe for bathroom sink to code Lindy_B Plumbing 0 02-17-2011 09:34 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 12:14 PM
Sink Drain LaMarguerite Plumbing 2 10-22-2008 04:26 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
