Old 03-11-2005, 11:34 PM   #1
Question
sink drain
I am renovating a old bathroom, I'am putting in a pedisal sink can I recces it into the wall 2", because the toilet is tight to the exterior wall with a window in it. I need to move the sink back a little because the drywall is starting to rot behind the toilet, so I'am tight for room between the sink and toilet once I move the toilet ahead. My problem is I need to be able to abandon the drain location and tie into the stack in the basement below the floor joist, if I do this will it work and still be vented properly.
Ben kiemele is offline   Reply With Quote
Old 03-15-2005, 07:03 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
sink drain
The toilet should be 12" on center out from the finished wall over the toilet flange and closet bend. A toilet has a built-in trap and is vented by the stack. The flange should be bolted to the top of the finished floor with only the thickness of the flange above finished floor level, and the toilet leveled and bolted to the flange.
The sink should have a trap under it and drain into a 1.5" drain pipe that is vented after the trap back into the main stack above (usually from a T in the wall).
IF I understand what you're trying to do, you can't do it like that. I would get a smaller sink.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 01:53 PM
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 07:48 AM
