Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2008, 10:39 PM   #1
Sink Drain
I want to install a 13" deep (drop in) kitchen sink on a 36" high cabinet. The sink drain pipe was installed at 20" off the floor, leaving 16" for the sink (13"), drain (2") and tailpiece.
Will I be able to install the sink if I only have about 1" left for a tailpiece to go into the P trap, or must the drain pipe be lowered?
LaMarguerite is offline   Reply With Quote
Old 10-21-2008, 11:32 PM   #2
Registered User
Termite's Avatar
Might be a challenge because the thicker hub portion of the tailpiece is longer than an inch.
Old 10-22-2008, 04:26 PM   #3
unconvetional
There are circumstances where I've had to use a regular ell instead of a street ell on the trap with a short piece of pipe between the u - part of the trap. And another time when I was desperate on a basement sink I (don't judge me please) a 3" x 6" drum trap. No disposer.
plumcass is offline   Reply With Quote
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 09:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
