Sink Basin's Chrome Drain Elbow Soldered? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 10:11 PM   #1
Question
Sink basin's chrome drain elbow soldered?
I have some chrome basin plumbing set up as shown in the link below. The final "elbow" piece that goes to the wall looks to be be soldered inside of the pipe from the wall.
Is soldering this normal?
My problem is that that elbow piece broke and I'm not sure how to get it out properly to insert the replacement elbow?
http://kitchenbathroomfixtures.com/s...in-p-trap.html
Lance
sting is offline   Reply With Quote
Old 07-25-2012, 10:24 PM   #2
Could you provide a pic of the broken elbow? Removing it depends on what type of material it is.
VIPlumber is offline   Reply With Quote
Old 07-25-2012, 10:29 PM   #3
It's exactly what's shown in that link... I think it's chrome plated brass... the stuff from days of old that I'm not sure they really use anymore...
Old 07-25-2012, 11:19 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 436
The link just shows a common chrome p trap. Sounds as though yours is set in lead. Not an easy fix
Sent from my iPhone using DIY Forum
Old 07-26-2012, 10:16 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Sounds like you have a solder bushing in a galvanized or cast iron fitting. It should unscrew with the help of a large pipe wrench. I've had a few times where I was very lucky and they came out easy.
Most of the time it's very awkward trying to get a wrench big enough on it to get enough leverage to get it to turn.
If it won't turn, the other option is cutting it out, and that can be tricky, frustrating, and also runs the risk of damaging the fitting in the wall if you don't know what you're doing.
Sorry to say you most likely don't have an easy one here.
Journeyman Plumber
Old 07-26-2012, 10:18 AM   #6
Doing it myself
Alan's Avatar
I bet it looks like this at the wall :
http://www.plumbing-geek.com/images/sweatbushing.jpg
Sometimes i've seen them inside of the wall where they aren't accessible.
Journeyman Plumber
Old 07-26-2012, 10:28 AM   #7
OK, OK, here are some photos!
The first shows that it's a chrome plated brass pipe and the second shows a closeup of the actual connection...
How should I proceed to get it out?
Also, if you look at the link in my first post, the new elbow is just a pipe with no threads or anything, so how does it connect up?
Lance
Sink basin's chrome drain elbow soldered?-imgp0001-001.jpg   Sink basin's chrome drain elbow soldered?-copy-imgp0001-001.jpg
Old 07-26-2012, 10:35 AM   #8
Doing it myself
Alan's Avatar
Open the drywall 1/4 to 1/2" around the pipe to see if you see a female threaded fitting in there.....
Journeyman Plumber
Old 07-26-2012, 10:35 AM   #9
Lightfoot's Avatar
Rewards Points: 272
couldn't you just cut the elbow part off at the straight section which is soldered, and use a plastic slip joint from there on out? From the pix, it looks like there's enough room. A couple inches of straight is really all you need to make it work.
Lightfoot is offline   Reply With Quote
Old 07-26-2012, 12:38 PM   #10
For a slip joint don't you need threads on one of the pipes? The new chrome elbow would not have threads (see the photo linked in the original post).
Unless I could use a PVC elbow? It would connect to the chrome at the wall side... but would this connect to my chrome P trap at the other side?
Lance
Old 07-26-2012, 03:31 PM   #11
get what they use to call a repair trap.
http://www.grainger.com/Grainger/Rep...26-153660619-2
they also make them in pvc
http://www.amazon.com/Pvc-Sink-Repai.../dp/B000M2WAEU
Old 07-26-2012, 09:42 PM   #12
Doing it myself
Alan's Avatar
Lance
No, you can ACTUALLY use a slip joint coupling to make the connection to what's left of the chrome trap when you cut it. I've seen this done a bunch of times, and it ends up failing when the leftover part of the chrome p-trap rots out.
Fix it once, fix it right.
Journeyman Plumber
Island sink drain problem oldphoneman Plumbing 2 02-06-2012 11:56 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 01:37 PM
Pedestal Sink Drain Meridius Plumbing 9 11-11-2010 01:19 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
