Old 10-29-2010, 11:14 PM   #1
Sink In The Basement
I am in the process of finishing a bar in my basement and want to install a sink. I have already run the water lines to the location, but am unsure about the drain/vent. The sink will be located approx. 5ft from my 3" main stack running up to the main level...
I assume I can cut into the main stack and run my drain, but can i cut in and run my vent through there too?
cubfan12 is offline   Reply With Quote
Old 10-30-2010, 12:16 AM   #2
call me E
TheEplumber's Avatar
Nope. You need to tie the vent into another vent on that floor or upstairs. You cannot tie it into waste stack. You should check your local codes. They may be different.
Old 10-30-2010, 07:56 AM   #3
Super Moderator
There is a pump with a plastic box designed for isolated sinks like yours--that might allow you to move the sewage without breaking concrete--
Call a plumping supply house and ask about them.---I don't know if this is a possible solution in your case--Mike--
oh'mike is online now   Reply With Quote
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Installing shower & sink in basement Sporty40 Plumbing 1 10-09-2010 06:42 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
