Single Lever Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2010, 11:56 PM   #1
Single lever faucet
I just did a remodel in my master bathroom and installed single lever faucets. Unfortunately I just discovered that there is not enough room to turn the level all the way to hot. Please tell me there is an easy solution to this! Thanks!
ElisabethF is offline   Reply With Quote
Old 05-27-2010, 12:00 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Without seeing the issue and reasoning, it's kind of hard to make a recommendation. Can you post a picture and/or make a more in depth description of what is in the way?
Journeyman Plumber
Old 05-27-2010, 12:04 AM   #3
Sorry for not being more precise. I have this faucet:
http://www.designerhardware.com/Flui...fld-f13001.htm
And I have just realized that it is installed too close to the wall so I can't turn the lever far enough to get hot water.
Hope this is clearer.
Old 05-27-2010, 12:05 AM   #4
Doing it myself
Alan's Avatar
Is it installed on a drop in oval lavatory, an undermount (hole drilled in countertop) or a one piece cultured marble kind of deal?
Also : How much more clearance do you need for it to turn all the way on?
Journeyman Plumber
Old 05-27-2010, 12:09 AM   #5
The hole is drilled into the countertop. The lever need to go down another 40 degrees to get to the maximum hot position.
Old 05-27-2010, 12:14 AM   #6
Doing it myself
Alan's Avatar
40 degrees is kind of a lot....
What I would do :
Pull the faucet off the countertop
measure the base of the faucet (the part that covers the hole)
Measure the size of the hole and figure out how much fudge room you have.
Check the mounting hardware to determine whether enlarging the hole will screw up the way the faucet mounts to the countertop.
Check below the countertop to make sure you have clearance to move the hole closer to the lavatory.
Make sense?
In short its not going to be easy.
Journeyman Plumber
Old 05-27-2010, 12:22 AM   #7
Yes, it does make sense. Unfortunately, there isn't much room to move the faucet forward regardless of the size of the hole.
Is there any way to adjust the lever so I bring the whole thing forward? Meaning I have another 50 degrees on the front side so if I can get the position of the levers moved forward, then I can have access to the full range of temperature.
Does that make sense?
Old 05-27-2010, 07:32 AM   #8
Knows everything but that
Rewards Points: 150
That would have been my first thought, instead of moving the hole. Im not sure Id enjoy disassembling a 300+ dollar faucet but if you cant return them for something else then thats what I would be doing.
JakAHearts is offline   Reply With Quote
Old 05-27-2010, 08:57 AM   #9
Doing it myself
Alan's Avatar
You could try it... unfortunately that looks like some kind of exotic specialty faucet and I have no experience with it.
What I do know is that if you rotate the handle, it's going to look a bit funny when it's off....
Journeyman Plumber
Tags
single lever faucet
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 02:13 PM
Lever faucet loose; poor flow Toe Plumbing 2 10-12-2009 02:44 PM
Replaced Single Lever Cartridge and now water is unpredictable BottomsUp Plumbing 3 06-11-2008 09:10 PM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 10:08 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 08:08 AM
