Single Lavatory To Double With Only One Cold/hot Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 10:43 PM   #1
Single lavatory to double with only one cold/hot line
Hello to all. This is my first post and I have a plumbing issue that I'm not sure about. I'm redoing a bath that has a single sink in the middle of the vanity. There is plenty room on top for a double sink but there is only one hot/cold water supply. Are there adapters that make the supply/drain system work? The cold and hot water supply would have to T off some how. The hot/cold supply is right in the middle and the drain is also. So everything would have to branch to the center from two sinks. If it can be done is it OK codewise or is there some issue with it? thanks, Don
T18skyguy is offline   Reply With Quote
Old 09-10-2010, 04:11 PM   #2
Rewards Points: 150
You should be able to do that, I posted a picture of dual outlet valves, it looks like I can't post what you need for the drain, a continuous waste, if you can't get on that's 1 1/4in get a 1 1/2in. and use two reducing washers.
braindead is offline   Reply With Quote
single handle or double handle faucet for bathroom aundav Remodeling 5 06-16-2010 04:56 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Mutiple phone line needs an answering machine Densplace Electrical 5 04-04-2008 10:35 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
