Single Handle Washing Machine Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2013, 07:17 AM   #1
raylo32's Avatar
Rewards Points: 1,226
single handle washing machine valves
After someone in a friend's condo building had a washing machine hose blow (what a mess!) I am looking into replacing my basic boiler drain valves with one of those single handle ball valves that are easy to shut off. Also found this one that has a manual timer that automatically shuts the valve after 2 1/2 hours. These seem to be a no-brainer good idea but wanted to check with you guys to see if there are there any downsides to these types of valves...
http://www.amazon.com/s/?ie=UTF8&key...sl_egzo3nzjo_b
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 08-16-2013, 10:08 AM   #2
raylo32's Avatar
OH' Mike?
Oh' Mike, You have any opinion on this?
Old 08-18-2013, 07:28 AM   #3
raylo32's Avatar
Well, this may be one of those jobs that really didn't absolutely need doing but I had the time and inclination... so I installed it anyway to replace the 2 old boiler drain valves that need a bunch of turns to close. My laundry is downstairs and we'll often run it in the evening at bedtime and just leave it until the next day. So this thing shuts the water off automatically after a fixed time, up to 2 1/2 hours. It uses a simple wind up spring powered timer that is wound and set by simply pushing the lever to the left. Can also be turned off manually with an easy flick. Works like a champ!
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 09:46 AM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 08:10 PM
Flood safe washing machine hoses ielliott Plumbing 4 12-25-2009 01:56 AM
