Single Handle Washing Machine Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2013, 08:29 AM   #1
Rewards Points: 43
We have a single handle washing machine valve that has become very difficult to turn on. It turns off easily, as it always did, but lately the
turn-on requires maximum effort to work. My wife cannot do it at all.
Do we need to replace the valve? Or is there something else I can to
to free it up? Thanks!
Jazan is offline   Reply With Quote
Old 10-03-2013, 10:06 AM   #2
Rewards Points: 286
It may be time to replace/rebuild the valve. You would have to turn the water off and take it all apart to rebuild it. It may be easier to replace it. They wear overtime and depending on how hard your water is, they can build up sediment. Please post a couple of pics so we can give you better advice. Thanks.
Just a suggestion; Along with replacing/rebuilding the valve, replace your hoses at the same time with some good braided ones.
jmon is online now   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
plummen (10-13-2013)
Old 10-03-2013, 12:19 PM   #3
Rewards Points: 43
Thank you, jmon, for the response. I will take it apart and see
what it looks like. Most likely, as you suggest, I will replace it.
Also, regarding the braided hoses, I have them installed already.
Wouldn't be without them after hearing of some true disasters
when the other type gave out. The one that comes to mind
has the washing machine on the second floor! The whole house
was ruined.
Old 10-03-2013, 12:56 PM   #4
Rewards Points: 286
Sounds good. Go from
there.
Old 10-13-2013, 08:46 PM   #5
Rewards Points: 43
A Generous Company!
I just got a surprise when I called Symmonds, manufacturer of the valve I've written about here. All I wanted to do was ask about my difficulty
moving the on-off lever to see if they had any suggestions. Instead,
they said they would replace it immediately and they sure did. They
Fedexed it overnite and it was delivered the next day at noon.
I had told them I had operated the old one for many years, and I was
was not calling to complain. They said it should not have failed that
way and they would replace it. How about that? I've never dealt with a company like that. Wow!
The Following 2 Users Say Thank You to Jazan For This Useful Post:
jmon (10-13-2013), plummen (10-13-2013)
Old 10-13-2013, 09:05 PM   #6
Rewards Points: 286
It's always good to hear good news like that every once in awhile. Good for you. Glad everything worked out for you Jazan and thanks for sharing your experience with the forum.
Old 10-14-2013, 06:32 AM   #7
Rewards Points: 13,752
I'm wondering why your turning this valve on and off all the time.
Old 10-14-2013, 07:02 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Some people turn the water supply off when not in use. It is a very good idea as it will prevent a flood if a hose were to burst. I do it when I go off on vacation.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
djlandkpl (10-14-2013), jmon (10-14-2013)
Old 10-14-2013, 07:15 AM   #9
Rewards Points: 1,314
The valve is off and on all the time because that's what the design was made for and these folks aren't only a cut above in what should be done but actually do it.
Old 10-14-2013, 07:32 AM   #10
Rewards Points: 2,516
To use it for the intended purpose I would assume. Dont you? Or do you not have this technology?
hammerlane is offline   Reply With Quote
Old 10-14-2013, 07:48 AM   #11
I'm wondering why you would question why?
Old 10-14-2013, 10:24 AM   #12
CitadelBlue's Avatar
Rewards Points: 97
These valves should be "code", considered "standard" and should be located above the height of the washing machine for easy access. I've been using one of these for 20 years and always turn off the water when we are finished washing. I've seen too many flooded basements and ruined floors and ceilings.
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
Old 10-14-2013, 03:56 PM   #13
Ive been using them for 3 years since we moved laundry to 1st floor.
Old 10-14-2013, 08:01 PM   #14
747
registered
747's Avatar
Rewards Points: 534
Yes those are nice. They also make electric one which does it automatically. Your a big player having one of those. Major upgrade
747 is offline   Reply With Quote
Old 10-14-2013, 09:24 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 684
Unfortunately "code" is written to protect your health- not your property
Tags
washing machine valves
Washing machine supply valve leak adoggg Plumbing 14 10-16-2013 06:25 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 04:17 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
