Old 06-09-2009, 06:25 PM   #1
Single-handle faucet - water either hot or cold.
Hello everyone,
My kitchen faucet (single-handle model, brand not identified yet) is sporting two rather annoying problems:
  • It runs either hot or cold water. To get a reasonably warm water from it, I have to perform very delicate tuning of the handle.
  • Water pressure from the faucet is somewhat weak.
Could anyone suggest a way to fix this (short of replacing the whole assembly)?
Thanks in advance.
abelikoff is offline   Reply With Quote
Old 06-09-2009, 06:58 PM   #2
Is your water pressure ok in the rest of the house??
If so, try taking the screen off the end of the faucet and opening the hot and cold wide see if the flow is better if not tell us.
SULTINI is offline   Reply With Quote
Old 06-10-2009, 06:51 PM   #3
Thank you for the reply. Pressure is fine in other faucets (it's an apartment building). I am actually more concerned about inability to mix warm water in a reliable fashion.
The faucet is Franke FF-200. I called them and they suggested to start with the flow restricting part on the flexible extension pipe - he suspected it could've been either set to a too restrictive a value or clogged. Still not sure if it solves the mixing problem.
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 23 08-24-2010 03:42 PM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 06:18 AM
