#1 |
Single drain with disposal
I have a question, I have a centered drain now and the drain happens to line up with the sink drain, now I have to add a garbage disposal unit, this makes it tricky because I have to saw the drain pipe shorter. I wanted to know what are the restrictions in the number of turns or kind of turns that I can do before it enters the wall?
Can I rotate the outflow tube of the disposal so it points diagonally instread of straight down, then add a 45* elbow into the P trap? Is this the best option to add some pipes so the P trap can be at the back of the disposal? The drain is a little high but as long as the disposal outlet is higher than the P trap will work right? Thanks for your advice!! Last edited by DIYGST; 01-26-2009 at 04:33 AM. |
#2 |
The most basic rule is: the more turns in a drain, the more chances for a clog, keep it simple. Use 45 instead of 90 deg. If I understand what you plan, sounds OK to me. Space under a sink is always limited, so you make turns where you have to to get to the wall.
| Display Modes | |
| 2" drain in sink for garbage disposal? | robhag | Plumbing | 8 | 04-25-2012 09:54 AM |
| Sudden SUPER slow drain in kitchen through disposal | pcampbell | Plumbing | 11 | 11-07-2008 06:13 AM |
| Wierd Floor Drain "Backup" | rawkintrevo | Plumbing | 9 | 06-04-2008 08:10 PM |
| The Bioswale, french drain, deck, drainage dilemma (long) | seabright_sc | Building & Construction | 2 | 01-05-2008 04:37 PM |
| Disposal & Sink w/back set drain??? | Kathy | Plumbing | 2 | 03-04-2007 03:48 PM |
