Old 02-14-2012, 04:41 PM   #1
Single/double throw water heater t-stat..
Hey everyone,
What's the difference in function between a single and double throw water heater t-stats?
Thanx
Bulldoggish is offline   Reply With Quote
Old 02-14-2012, 11:01 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Well in my mind a single throw switch is basically on or off,a double throw could be on or off either direction like a 3 way light switch.
I guess Ive just never thought of it in terms of a thermostat for a water heater
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 11:11 PM   #3
are are referring to the difference between the upper and lower thermostats? the upper one switches the power to the lower thermostat after the upper part of the tank reaches temperature. on a cold tank the upper heats first and when the thermostat shuts off the upper element the lower thermostat is energized.
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
low pressure after hot water heater replacement tuffluck Plumbing 4 06-07-2011 04:14 PM
Smelly brown water from water heater timthetoolman Plumbing 2 05-19-2011 10:32 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
