Single To Double Sink Problems. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2014, 02:57 PM   #1
single to double sink problems.
So I got a brand new double bowl vanity. 1 drain stubout. what I did was used a Y connection at the stubout, ran sink 1 ptrap off the extension tube. over aprox 20 inches and connected sch. 40 PVC into the Y. Drain 2, extension tube Ptrap then into the Y connection. I used an air admittance valve off the top of the Y because I thought it would fix this problem.
The problem:
when sink 1 is on it fills up rather quickley and drains slowly. When sink 2 is running it drains fine but sink 1 starts to fill back up (back feeding into sink 1.) all lines were routed with schedule 40 PVC, 1 1/2 inch. I personally feel that its too much water rushing for the single drain outlet to handle or maybe a partial clog somewhere? Please help!
mikemarshall150 is offline   Reply With Quote
Old 04-24-2014, 04:06 PM   #2
Rewards Points: 282
Welcome to the forum mikemarshall150.
Water will take the path of least resistance.
Introduce yourself a few more times and please post some pics of under the sink setup so the plumbers can better assist you. Thanks.
jmon is offline   Reply With Quote
Old 04-24-2014, 05:06 PM   #3
I am an advanced DIYer. I have work on numerous projects and have basic knowledge and understanding. Law is my day job but I have enjoy tiling, drywall and doing my own projects.
Old 04-24-2014, 05:08 PM   #4
Rewards Points: 26
Not vent issue. Partial clog, snake the line.
SHR Plumber is offline   Reply With Quote
Old 04-24-2014, 05:48 PM   #5
I do have access where the 2 1/2 inch brass drain line goes into a y into the main stack in my basement (ranch house). I will disconnect that line and run a snake and see what I can find. I know its not near the vent because I replaced the vent during a bathroom remodel and the cast iron looked brand new. Finger's crossed. !!
Old 04-24-2014, 07:52 PM   #6
Rewards Points: 26
In order to clear the drain line snake from the sink drain trap adapter under the sink.
Old 04-24-2014, 08:26 PM   #7
I snaked the line just before install. Could the problem be where the brass 1 1/2 meets the main line ?
Old 04-24-2014, 08:29 PM   #8
Rewards Points: 1,952
Do us a small favor and post a picture of what you have done.
The Following User Says Thank You to Ghostmaker For This Useful Post:
LateralConcepts (04-24-2014)
Old 04-24-2014, 09:12 PM   #9
I will post a picture when I get a chance tomarrow. everything is brand new except the stub out in which I did run a manual snake down about 10 feet or so and pulled it back out. I was thinking about it and I did have a slow drain even when I had the single vanity. drain cleaner would fix the problem for about a week then back to a slow drain. Would I be wrong is saying that I do now think it is a clog slowing things down.? That drain should not be backing up so quickley. 1 1/2 inch drain pipe should be able to take a substancial ammount of water from both sinks before filling and bringing the water back up the ptrap. Correct?
Old 04-24-2014, 09:32 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 676
1.5" is code compliant for the trap arm. I agree with others that your line is plugged.
Don't use a chemical cleaner though-BAD stuff. Use a snake for best results.
The Following User Says Thank You to TheEplumber For This Useful Post:
SHR Plumber (04-25-2014)
Old 04-24-2014, 11:09 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 996
double sinks on a 1 1/2 arm is stretching it, not allowed under IPC partial clog plus over loaded waste arm equals your problem, assuming theres nothing else piped in wrong.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
MTN REMODEL LLC (04-25-2014)
garbage disposal under double sink debiasio Plumbing 3 01-02-2015 11:27 AM
Double pole vs single pole question Araucaria Electrical 5 04-24-2012 08:20 PM
Drainage problems kitchen sink only. Raytanner Plumbing 1 01-10-2011 07:00 PM
Double sink bathroom rough-in MikeyP Plumbing 2 09-30-2008 09:29 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 09:20 AM
