Old 11-30-2012, 11:39 PM   #1
Special User
Simple single handle 3/4" tub/shower valve: no such thing?!
I'm planning my bathroom remodel and want to put in a 3/4" tub/shower valve. I don't really care if it's thermostatic, but all the 3/4" valves seem to be, so, whatever.
Thing is, I'm having a hard time determining if these things require a separate volume control handle when used with a diverter spout.
For example, the Kohler K-2975 valve says you need a K-9663 "double ell" aspirator when using a diverter spout. Ok, fine. But I still can't tell if I need a separate on/off control? Same question with a Moen Exact-temp S3371 or American Standard R530.
All the tub/showers I've ever used are either push-pull off/on, or, shut off when moved past the full cold position. That's exactly what I want, only in 3/4". Does such a thing exist?
EDIT: Ok, I'm disappointed. The Moen requires a separate on/off per their FAQ page. The American Standard requires a separate on/off on their spec sheet. The Kohler requires a separate on/off per the K-9663 install sheet. Ugh.
However, the Hansgrohe iBox 01850181 looks like it might be the ticket! Ha, leave it to the Germans to get it right!
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-01-2012, 05:58 PM   #2
The Kohler website says separate volume controls are required for each outlet off the K-2975.
The K-2971 is a 3/4" valve that is a positive shut-off (no volume controls required), but you still need the twin ell if you're using a diverter spout.
Ishmael is offline   Reply With Quote
Old 12-01-2012, 10:46 PM   #3
Special User
Nice find, thanks! Your Google-fu is strong.
Old 12-10-2012, 08:55 PM   #4
Special User
I just got my Hansgrohe single-handle pressure-balance trim, and I have to rave about the engineering on this thing.
First, the iBox is genius. One rough-in can be used with pressure balance or thermostatic cartridges. Change your mind? No need to rip out your tilework. And, of course, the iBox is a full 3/4" and not a wimpy 1/2". It also comes with a plastic shell to direct any leaks out of the wall cavity, to save your framing. Smart.
Then, the pressure balance cartridge. Unlike other manufacturers, this one does NOT require a "double ell" or "twin ell" when used with a tub diverter spout. Of course this information was hard to come by. I couldn't find any information online except the Hansgrohe FAQ that states that one of their obsolete valves doesn't need a twin ell. I finally had to email Hansgrohe support to confirm that the new models also do not need a twin ell.
Not needing a twin ell is nice, because a twin ell restricts flow. Check this out:
http://www.terrylove.com/forums/show...l=1#post251819
Internally, that thing has a pitiful 1/4" opening for the tub spout! A lot of it has to do with preventing the shower head from spitting water when you're filling the tub for a bath. Too much flow backs up at the spout and gets pushed up the shower riser. That's because a twin ell depends solely on the water's velocity to not turn 180° and go up the shower riser. Do anything to kill that velocity, like open up the tub filler passage, and you get unwanted shower flow. So your tub must fill slowly.
Instead, Hansgrohe uses what appears to be a venturi. Looking at the internal passages and orifices, I can see a small hole for the upper shower output intersecting the increasing-diameter lower tub spout output. With the spout diverter open, air could actually be entrained from the shower head and into the tub spout (that's a venturi's purpose in life, after all). So now your tub filler can be full flow without risking water backing up to the shower. In-freakin-credible genius there, guys.
Now, before I start to sound like a Hansgrohe shill, I still have some gripes. Like, not just Hansgrohe, but for just about any valve except Moen, it's really hard to find out how to operate them. I searched and searched Hansgrohe's website but could not find if their pressure balance was pull-on push-off twist-temp like Moentrol, or if it was more like Positemp, or what. Not until I actually got the thing in my hands did I find the documentation it came with that showed 6 o'clock as off, 5 o'clock as cold, and 3 o'clock as hot. Such a short throw is gonna make it hard to dial in the right temperature, vs say Positemp which has a much wider range of travel. Not only is a short throw annoying, it's doubly annoying you can't find that information until after you've already bought the valve and it's too late to change your mind.
Simple single handle 3/4" tub/shower valve: no such thing?!-hansgrohe_pressure_venturi.jpg
Old 12-10-2012, 09:24 PM   #5
call me E
TheEplumber's Avatar
I've always liked Hansgrohe and if you would've hired me to plumb that valve in- I would have given you the address of my wholesalers showroom so you could try it out before you bought it
Moen single handle shower valve n224ap Plumbing 3 09-23-2011 07:04 PM
Can't remove bath tub handle valve stem. kuyaariel Plumbing 13 05-03-2011 12:20 AM
Stubborn Handle on Hot Water valve cody21 Plumbing 1 05-23-2010 07:40 AM
Can I use a mixing valve for tub/shower in a shower only application? jayp Plumbing 1 01-21-2010 09:37 AM
NIBCO hose bib valve stem handle shape Plumbing 2 02-28-2009 07:23 AM
