Simple Question - Trim Pipe Or Replace It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2011, 10:05 PM   #1
Simple question - trim pipe or replace it?
Hey everyone,
I'm replacing my vanity in my condo. The new vanity requires a shorter drain/p trap.
Can I unscrew the current pipe and buy a shorter one from the wall, or must I use a hack saw and saw it off?
Thanks for the help!
Simple question - trim pipe or replace it?-photo-1-2-.jpg   Simple question - trim pipe or replace it?-photo-2-1.jpg
3dartist is offline   Reply With Quote
Old 05-23-2011, 11:10 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 684
That looks like a tailpiece extension. Is the end flared to receive the old trap? If it is you shouldn't use it Try a new p trap assembly. You'll have to cut it. Only available in a standard length
Old 05-23-2011, 11:10 PM   #3
I'd cut the existing pipe to the length required. It looks like you have lots of room to get the job done. Or you could unscrew it and replace. If you decide to go that route please note that chrome pipes are notoriously easy to crack, so be firm, but gentle, when removing it.
Either way be prepared to replace in case it breaks, as mentioned above.
VIPlumber is offline   Reply With Quote
Old 05-23-2011, 11:24 PM   #4
No, it's not flared. It's a straight 1.5 inch diameter pipe.
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Ventalation Pipe Question JordanB Plumbing 2 12-09-2010 12:19 AM
Poly Gasline to replace Black Pipe? GabeD Plumbing 9 08-29-2010 11:47 AM
Very simple stain question. dntnowood Painting 5 01-30-2010 06:37 AM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 08:32 AM
