Simple Question I Can't Find The Answer To - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-17-2011, 12:57 AM   #1
Rewards Points: 462
Simple question I can't find the answer to
What are the 2 screws for? Pressure adjustment or some form of disassembly?
Richo is offline   Reply With Quote
Old 07-17-2011, 01:14 AM   #2
the screws hold the unit together, do not remove them with the water on. if you need to make sweat connections to the inlet you can take the unit apart so it doesnt heat up then reassemble after the solder cools. they have small orings so if you take it apart dont lose them
Old 07-17-2011, 07:50 AM   #3
I haven't seen this exact type of valve before, but it looks like some type of mixing valve, made by Hansa. The screws look the same as the ones used on TMV,s I've serviced, which in those cases have been the filter and non return valve.
aussie steve is offline   Reply With Quote
Old 07-17-2011, 08:11 AM   #4
Rewards Points: 1,214
It's just a washing machine shut off valve that shuts hot and cold off at the same time.
COLDIRON is offline   Reply With Quote
Old 07-17-2011, 09:58 AM   #5
Rewards Points: 462
My girlfriend has one of the valves in her house but she says that when you wash in cold water the washer takes forever to fill up so she was wondering if it was possibly a water pressure adjustment screw.
Apparently not
Thanks for the replies.
Old 07-17-2011, 10:11 AM   #6
Plumb or Die!
Check to see if the washing machine hoses have screens in the ends. Could be clogged up with scale.
plumber666 is offline   Reply With Quote
The Following User Says Thank You to plumber666 For This Useful Post:
DangerMouse (07-17-2011)
Old 07-17-2011, 10:27 AM   #7
Rewards Points: 462
Good idea. Thanks.
Old 07-17-2011, 11:20 AM   #8
also some washing machines have a screen inside the connection for the hoses on the back of the machine. chech there when you have the hose disconnected to see if there is a screen in it.
Simple hole question vandrem Drywall & Plaster 10 07-01-2011 07:48 PM
Attic Insulation - Can't seem to find the answer Ags Win Building & Construction 8 06-29-2010 07:05 PM
Got a Question I can't answer ladymacbeth General DIY Discussions 3 11-27-2007 11:19 AM
Simple code question mdalli HVAC 1 11-03-2007 04:36 PM
simple question djcrewz Electrical 7 10-25-2005 12:01 PM
