Simple Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-05-2013, 08:34 AM   #1
Rewards Points: 85
Simple Question
Hi!
Was helping my bro inlaw with his sprinkler system and he was running copper pipe to the PVC valves but burying the copper. I didn't think it was a good idea. Felt it will corrode quickly. Am I wrong?
Thanks!
JohnC20 is offline   Reply With Quote
Old 11-05-2013, 08:38 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Copper is used all the time buried. If the soil's Ph is way off to one side or the other you could have some trouble. Usually the green patina that forms will halt further corrosion.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-05-2013, 08:39 AM   #3
Rewards Points: 85
really!? That's good to know. I guess I owe someone some beer! Thanks!
Old 11-05-2013, 08:41 AM   #4
Rewards Points: 12,858
What's your location?
Adding it to your profile helps with suggestion on the best way and legal way to do things.
I can not imagine any case where I would use copper in a sprinkler system. Main reasons why, way to expensive, it will burst if it freezes.
Old 11-05-2013, 09:10 AM   #5
Rewards Points: 85
I'm on Long Island NY, in Nassau County. He used copper on the feed portion coming out of the house and to the anti siphon valve. Then to the solenoid valve box under ground. All in all it was about 5ft of copper. I think he had it in his garage and wanted to use it up.
Old 11-06-2013, 06:48 AM   #6
PoleCat's Avatar
PVC will burst too if it is not blown out at the end of the season.
Old 11-06-2013, 07:14 AM   #7
Rewards Points: 85
Yes. Learned that the hard way
Simple Storm Door, screw question SER56 Windows and Doors 8 12-26-2012 08:57 AM
Simple question, difficult answer??? HELP! rozzy1978 Electrical 2 11-02-2012 11:46 AM
Simple grounding question fgunternahrer Electrical 7 09-04-2012 06:43 PM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 10:32 AM
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 08:46 AM
