Old 09-17-2007, 07:46 AM   #1
simple leaking tap question
Hi all, the hot and cold taps where leaking in my bathroom, water was leaking though the top of the spindle, not out of the heads.....replaced the o ring , seal and washers etc, still leaked....then installed new complete inner boddy assembly with all new seals etc for both hot and cold....the hot is now ok due to the poor pressure, but the cold only leakes through the spindle when half open to full open, dose this mean my cold water pressue is to high and so forces water past the oring and out of the spindle?..
ie when fully closed, no leaks,seating is ok, when open more than half it leaks out the spindle..?
fridgeman is offline   Reply With Quote
Old 09-17-2007, 07:54 AM   #2
Remodeler
MinConst's Avatar
Sounds to me like your not tightening the spindle nut enough to put pressure on the the seal. A new fitting should not leak. Try tightening the nut a little more until the leak stops.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 09-17-2007, 08:00 AM   #3
On older taps there's a nut on top which can be screwed down to compress the hemp packing. On most taps though there's a groove in the shaft with an O ring in it. As the spindle threads wear the spindle gets a bit of slop in it which chews out the O ring. When the tap os closed there's no leakage as there's no water pressure until the tap is open. Thats why i replaced the whole inner assembly....still leaks out the spindles...unless i brought the wrong size or something..
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
simple frig waterline question weiside Appliances 6 08-01-2007 11:30 PM
Are roof skylights leaking? Halron Roofing 3 04-15-2007 03:06 PM
simple question djcrewz Electrical 7 10-25-2005 12:01 PM
