Simple Caulking Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2012, 07:40 PM   #1
simple caulking question
would you guys silicone around this?
I want to but I have a feeling it's going to be such a thin bead that it will fail. let me know if it makes sense to go out and buy the silicone for this...
sannitig is offline   Reply With Quote
Old 11-21-2012, 07:52 PM   #2
Rewards Points: 13,300
It needed to be caulked or Plumbers puddy under the lip of the sink before it went in not after.
It's going to do 0 good to just try and caulk around the outside lip of it now.
Old 11-21-2012, 08:03 PM   #3
Sorry I forgot to mention it was installed properly...silicone 1 around the lip underneath....
So what do you guys think about the original quotation?
Old 11-21-2012, 08:04 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
I very seldom use 100% silicon caulk. I like Dap latex kitchen/bath caulk. Apply a bead on the top before setting the sink. Then a bead after sink is anchored. Use your wet finger to push it into the voids at the edge. Dap is water based so it cleans up real well. Just don't apply it on a wet surface
Old 11-21-2012, 08:22 PM   #5
Ok thanks...I will apply some.
I was just concerned that it was such a small bead that it may just come undone
Old 11-21-2012, 08:57 PM   #6
Rewards Points: 582
if it was done right ..why do it now that small edge won't hurt anything as long as it not leaking...ben sr
Old 11-21-2012, 09:09 PM   #7
Insurance? Piece of mind?....there was one spot where the laminate did chip...the sink covers it but still...you know?
Old 11-21-2012, 09:13 PM   #8
Rewards Points: 582
it really should be fine...but if you feel better doing it..i would use 100% clear silicone very small bead....ben sr
Simple question on transformers from a n00b turborunner Electrical 4 06-13-2012 12:49 AM
simple question regarding kitchen sink drain donkeyk Plumbing 6 05-31-2012 10:32 AM
Simple Question on Light Switch Series hagler Electrical 19 03-20-2012 08:46 AM
Simple Countertop Question DrHicks Kitchen & Bath Remodeling 3 09-15-2011 05:14 PM
Caulking question? jad Painting 3 09-07-2010 02:44 PM
