Simple Caulking Cleanup Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2009, 08:52 PM   #1
transmitterrecieverpntgun
simple caulking cleanup question
I just caulked the new tub surround (plastic 3 piece) and ofcourse, even with the tape it still got out of controle. What is the best way to clean it up and wipe away the little smears of caulk with out ruining/disturbing the caulked joints....
utilitylocator is offline   Reply With Quote
Old 02-10-2009, 09:21 PM   #2
Rewards Points: 2,906
Probably with Dap Silicone-Be-Gone silicone remover, which you can find in the caulking aisle of your home center, or with paint thinner. You can buy plastic razor blades at Lee Valley. Just scrape as much as you can off with the plastic razor blade, and then remove the rest with Silicone-Be-Gone or paint thinner.
Also, some people in here are telling me that paint thinner or Silicone-Be-Gone might damage the finish on a plastic tub. In all the plastics I've ever used, I've never seen one that was damaged by paint thinner, but I'm telling people to use both products in an inconspicuous area first before using it on their tub.
Right now I'm waiting for my local plumbing wholesaler to break up a plastic tub (rather than return it to the factory) so I can get a piece of the same kind of acrylic plastic that tubs are made of to test bleach, paint thinner and silicone-be-gone on it.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-10-2009, 09:27 PM   #3
Thanks for the information. By the way, I bet if you go Craigslist you will find someone giving away a free tub. Even a plastic one...
Old 02-10-2009, 09:36 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
When I install acrylic/FG systems, we use an adhesion promoter (silicone primer that makes the silicone stick) but I am surprised that I can not find this product on the open market (i.e. the home stores). I know that some silicones boast that no primer is needed, but I have found that if it is not used on acrylic/FG, it can easily be pulled off the system. Maybe because it can cause damage if not used properly, but that can be said for many products.
One good rule of thumb, is 'less is more', meaning, that you can actually over-caulk. Do what is needed, but not so much that you are spreading the sealant over areas that need not be caulked.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 02-11-2009, 11:13 AM   #5
For silicone removal on scratchable surfaces, I use plastic putty knives from Walmart. They can even be "sharpened". Then I use isopropyl alcohol to remove the rest of the residue. I cannot imagine paint thinner not removing the clearcoat finish.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Simple wall framing question.. jogr Building & Construction 7 10-28-2008 10:43 AM
Simple wall switch question LZCenter Electrical 8 06-30-2008 10:01 AM
caulking question Mack V Painting 14 01-17-2008 08:29 AM
oak trim, caulking and paint question THEBIGPUNN Painting 2 06-05-2006 09:28 PM
simple question djcrewz Electrical 7 10-25-2005 11:01 AM
