Simple Bathtub Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-11-2010, 10:40 AM   #1
Simple bathtub question
Hi, I had a few questions about this bathtub shown above:
1. Are the gaps that are pointed out by the red arrows supposed to be caulked or should they be left uncaulked?
2. I bought the house from the original owner, and it was uncaulked when I got it. It seems that it should be sealed up, as I believe it is causing water to leak to the ceiling below. But when I press on the big panel facing us, the panel moves in about 1/4 inch. What's the best way to seal this?
3. There still seems to be a plastic wrap on the panel facing us, I'm assuming that should be removed as well, and is not some type of surface layer that is coming off. (Picture below).
Thanks for your help.
Joe
joebann is offline   Reply With Quote
Old 09-11-2010, 11:59 AM   #2
Rewards Points: 276
I can't see the above picture you are talking about. The other picture is too close up. Is that a drop-in tub with a removable apron? It seems like it could be caulked if you don't need to remove the panel for access. If it is something like a Jacuzzi then you need that access for the plumbing and electrical. Wherever your water leak is coming from, it needs to be remedied.
Jim F is offline   Reply With Quote
Old 09-11-2010, 02:59 PM   #3
It doesn't look like it should be caulked to me. It's outside the tub, and there may be a need to get in there. To me, the problem seems to be the water on the outside of the tub. Proper positioning of the curtain, or one of these http://www.homedepot.com/Bath-Tubs-W...atalogId=10053 will keep the water in the tub. If the leak doesn't go away, you've got another problem
the_man is offline   Reply With Quote
Old 09-11-2010, 07:47 PM   #4
The following a link to the picture in case it can't be seen.
http://img214.imageshack.us/img214/2561/dscf1811d.jpg
So I am concluding that it shouldn't be caulked, and as long as no water runs to the outside of the tub, I should be fine.
As I have 2 small children, who tend to splash a lot, this is probably the reason I'm getting the water outside the tub. I opened a hole in the wall behind the facet, and see no other signs of water damage besides that next to the panel in question.
I'll look into the term "drop in tub", and see if this is what I have. As far as I can see from the hole that I made, the tub and that panel are separate, and there is no electrical to access under the tub.
If you have any other advice to avoid water getting into that gap, please let me know.
Thanks,
Joe
Simple question tamar120 HVAC 1 05-10-2010 06:06 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Simple grounding question. Wanttodoitright Electrical 16 03-20-2008 05:40 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
