Old 01-26-2010, 08:47 PM   #1
Silver solder on previous soft solder joints
I have a broken pipe going into a T-connector with sweated soft solder joints. The plumber told me that they now only use silver solder which uses higher heat and would damage the other two soft solder joints.
The plumber proposes to cut out the T-connector by cutting and connecting into the copper pipes feeding into it.
However it feasible to heat the T-connector, break the other two soft solder joints and remove the and replace the T-connector. But will the new silver solder joints be strong on copper pipe where there has been a soft solder joint.
Regards
GPS10 is offline   Reply With Quote
Old 01-26-2010, 10:18 PM   #2
Absolutely. Just make sure you clean the ends well. After you "un-sweat" (heat-up and remove) the old tee, wipe off the old solder with a rag while it's still molten; then clean the pipes with emery cloth.
The plumber may have suggested cutting/coupling because there may not be any "give" or "play" in the lines to move them enough to remove the old tee. You also have to get all the water out of the lines in order to melt the old solder out - sometimes that's easier said than done.
Ishmael is offline   Reply With Quote
Old 01-27-2010, 05:34 PM   #3
he is going to use silver for what reason again sounds a little weird who knows maybe there is a reason but ... What size fitting and what is the purpose of the line drain vent supply line residential or commercial ??
arcticbouncer is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Why Not Electronic Solder For Some Joints AllanJ Plumbing 16 02-08-2009 11:32 PM
