Silicone Caulking - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2012, 04:34 PM   #1
silicone caulking
how do I remove cured silicone caulking?
Clever is offline   Reply With Quote
Old 06-05-2012, 05:20 PM   #2
Rewards Points: 12,802
Where is it?
A single edge razer, then a green scubby pad works for me.
oh'mike (06-05-2012)
Old 06-05-2012, 07:24 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 802
Have any friends that are dentists? You know those tools that they use on your mouth to torture you? The work great for removing silicone too.....
Old 06-05-2012, 07:26 PM   #4
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
elbow grease and a razor blade.
wctekkk is offline   Reply With Quote
Old 06-05-2012, 07:39 PM   #5
Homerepairguy's Avatar
Rewards Points: 990
How about using two tools.
A razor scraper like this to cut the silicone ($10.01):
http://www.amazon.com/Titan-11030-Mu...8938643&sr=1-3
And a 5-in-1 tool like this to scrape/dig silicone out from the crevice ($7.23):
http://www.amazon.com/gp/product/B00...o_cart_title_2
I need to recaulk one tub/shower and am planning to buy both. Should come in handy for a lot of other jobs too.
EDIT:
Just noticed that the Titan razor scraper above uses a heavy duty razor blade. This razor scraper tool uses standard single edge razor blades ($10.51):
http://www.amazon.com/Lisle-52000-Ra...pr_product_top
HRG
Homerepairguy is offline   Reply With Quote
Old 06-05-2012, 09:04 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
A spray bottle of water helps too. I find keeping the surface wet minimizes the chance of scratching or gouging acrylic or fiberglass.
The Following User Says Thank You to Blondesense For This Useful Post:
Homerepairguy (06-05-2012)
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
removing silicone caulking Tooshadz Kitchen & Bath Remodeling 7 08-28-2014 09:47 AM
Removing silicone caulking Jra77 Windows and Doors 2 09-12-2011 07:38 AM
silicone caulking over ceramic tile grout joints tonyg2 Flooring 5 11-16-2008 09:48 AM
caulking trim with silicone castleconcepts Painting 2 10-24-2005 12:16 AM
