Silicone Caulk - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2009, 08:47 AM   #1
Silicone Caulk
What are your thoughts on using a silicone caulk to set a bath tub drain as opposed to using plumber's putty? Also what do you think of the American Standard "Americast" tubs?
joe3534 is offline   Reply With Quote
Old 10-19-2009, 10:25 AM   #2
It can be used, but makes removal a bit harder if it is needed. Americast has had problems in the past with the surface chipping and cracking. It has probably been solved. I still prefer real cast iron for tubs due the the stability and heat retention.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Removing Silicone Caulk... BillK40 Painting 39 10-28-2013 01:35 PM
Grout sealer before or after silicone caulk ? SPS-1 General DIY Discussions 2 07-28-2009 09:30 AM
removing silicone caulk from dryall, MDF 99BN99 Painting 2 07-12-2009 04:45 PM
silicone on silicone caulk ponch37300 Kitchen & Bath Remodeling 2 05-09-2009 08:11 AM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 08:03 PM
