Silicon Vs. Plumbing Putty: Does Plumbing Putty Discolor Cultured Marble? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2010, 03:21 PM   #1
Rewards Points: 152
silicon vs. plumbing putty: does plumbing putty discolor cultured marble?
Someone mentioned plumbing putty will discolor cultured marble & I should use silicon instead for under the drain & faucet in my bathroom sink - any truth to this?
lazzlazz is offline   Reply With Quote
Old 05-09-2010, 03:43 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Possibly.... silicone doesnt hold up. go find a non- staining putty for that application.
Journeyman Plumber
Old 05-10-2010, 04:01 PM   #3
Rewards Points: 152
It seems there is a lot of advice on the internet saying don't use plumber's putty on cultured marble and certain other substances sinks are made of. Unfortunately, my sink manufacturer's instructions are pretty pathetic and don't specify. Apparently, it's the oil in the putty that stains, and I cannot find any putty which says it is non-staining.
Old 05-10-2010, 09:49 PM   #4
Doing it myself
Alan's Avatar
"Sta put ultra"
Journeyman Plumber
Old 05-11-2010, 09:44 AM   #5
Rewards Points: 152
Originally Posted by Alan View Post
"Sta put ultra"
Thanks. I live 1.5 hours away from any of the big boxes & the choices here are limited (and the hardware employees had never heard of the stuff you listed). However, I do make the drive occasionally.
Old 05-11-2010, 09:30 PM   #6
Doing it myself
Alan's Avatar
I'd just order it online then....
Journeyman Plumber
Old 05-12-2010, 07:49 AM   #7
Lazzlazz, the warning pertaining to staining of marble by using Plumbers putty is on the can. It is due to the oil contant of the putty. 100% silicone should work fine.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
lazzlazz (05-21-2010)
Plumbers putty or Silicon Caulk? sukhenkoi Plumbing 2 04-21-2010 06:51 AM
