Silcock Will Not Shutt Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2011, 05:28 PM   #1
silcock will not shutt off
I have used the ouside silcock several times this spring but when I just went to shut if off it is still wide open. I turned it all the way to the right, tried adjust the stem nut, but the water is all the way on. Any suggestions short of changing it out?
cmshanley is offline   Reply With Quote
Old 05-07-2011, 05:37 PM   #2
Civil Engineer
Rewards Points: 4,520
You may have a rising stem sillcock, with a broken stem. If so, the cost and effort to repair will exceed many times the cost and time to simply replace the piece.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
cmshanley (05-08-2011)
Old 05-08-2011, 10:21 AM   #3
Just call me Andrew
Rewards Points: 1,020
You should have a valve in the basement near where the pipe leaves the house that will shut off water to the spigot.
Andrew
secutanudu is offline   Reply With Quote
Old 05-08-2011, 08:36 PM   #4
silcock will not shut off
I did shut the water off inside the house. Of course I just finished painting the house and now I have to do some hot work to replace the silcock and try not to burn the paint. Thanks for the advice.
