Silcock Replacement / Piping Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 11:22 AM   #1
Rewards Points: 45
In an attempt to replace my leaking silcock (outdoor faucet), I tried to turn the whole assembly counter clockwise. However, I didn't realize the joint was soldered instead of screwed and so the pipe was damaged. Hence, I will need to replace the piping on the inside of the wall. I've attached a picture of the piping configuration from the inside of my garage. Since the piping is extremely close to the wall, I was thinking of soldering a brand new assembly (everything above the blue and red sheathing) on my workbench and then installing it using sharkbite fittings. Would you recommend using these fittings or should I really do my best to try and solder everything? Also, is it a requirement to have a dead end piece of pipe installed above the tee where it goes to the silcock in order to serve as a water hammer arrestor? Not a big deal, just curious as to whether its really necessary. I will definitely be installing a threaded nipple at the tee where it penetrates the wall so that if the silcock needs to be replaced in the future it can simply be unscrewed. Thanks.
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 05-22-2011, 11:37 AM   #2
You can use the Sharkbites, if you want. I would get a piece of sheet metal and use it for a flame guard and sweat the fitting(s) in. Some States require the pipe for use as a water hammer preventer. Florida did. It is easier to keep the plumbing up to code while working on it than to have to go back later (should you decide to sell) and do it then.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
roof membrane repair or replacement lefleur Roofing/Siding 1 05-23-2011 04:55 PM
Double-hung windows - old ones - replacement or repair? spdorsey Windows and Doors 3 05-22-2011 10:08 AM
Central A/C repair ... or replacement price question bobssurfin Off Topic 3 07-12-2010 11:30 PM
Central A/C repair ... or replacement? pcampbell HVAC 29 04-24-2010 06:10 AM
Taco Valve Control Head Repair, or Replacement? s0lidgr0und HVAC 3 10-07-2008 11:10 PM
