Old 12-01-2012, 11:16 PM   #1
silcock to copper connection
i put in a new silcock exterior wall for outside water and wanted to connect it to the copper stub up for the kitchen (from the crawlspace). They are only a couple inches apart
Do I need a dialectric union to seperate the chromeplated silcock from the copper?
Should this connection be part of the plumbing rough in?
Finally should this connection be removable to help facilitate cabinet install, i guess the dialectric union could act as a union.
Thx for any help. just want to do my homework before the inspection.
john_bry is offline   Reply With Quote
Old 12-01-2012, 11:24 PM   #2
#1 Why are you running your supplys through the floor and not the bottom plate?
How would you ever change the valve if it fail of it's mounted that way?
And no you do not need a dielectric nipple.
Old 12-02-2012, 10:20 AM   #3
call me E
TheEplumber's Avatar
Add a piece of copper pipe to the bib so it stubs into the cabinet about 4" and secure the hose bib. That should be all you need for inspection Make it easy on yourself and don't connect it yet.
Shorten the stubs through the floor to about 8" and cap for inspection.
After you set the base cabinet you can make the final connection to the bib and sink in one go.
Old 12-03-2012, 01:57 PM   #4
Special User
I must not understand what you mean, I don't see how this layout would prevent future replacement as long as he uses a sweat-to-thread adapter for the bib?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
PVC Water Main Supply to Copper Connection jdobbs Plumbing 11 02-07-2012 12:01 AM
Copper look gutters but not as expensive ? Scuba_Dave Roofing/Siding 9 08-02-2010 10:23 AM
copper flashing, galvanized nails... sharp Roofing/Siding 4 04-02-2010 07:43 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 07:10 AM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 11:47 PM
