Shutting Off Water To House - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2010, 02:16 PM   #1
shutting off water to house
Hi, is there an order to this? I had a plumber over some months ago and he said you must shut the water off in a particular order (first the street, then the house, I think, but do not remember exactly). Does anyone know the order?
dwheelie is offline   Reply With Quote
Old 11-27-2010, 06:03 PM   #2
Rewards Points: 1,216
I shut my water off all the time when I go away for extended periods of time always in the basement I don't even go near the street and never had a problem. I didn't know it even mattered which one you shutoff as long as the flow stops.
COLDIRON is offline   Reply With Quote
Old 11-27-2010, 07:43 PM   #3
If you're doing any plumbing work after the main water entry in to your house, you'd only need to close the one inside your home. In my experience, you'll only ever need to shut-off at the street if the house shut-off does not close fully (And then I would replace it, these days with a 1/4 turn ball valve type).
VIPlumber is offline   Reply With Quote
Old 11-28-2010, 01:10 AM   #4
the only reason i can think of to have an "order" to it is so that you don't leave any sections of the pipe under static pressure. if you shut off the house valve, then the street the building supply might stay pressurized. i'd say shut off the street, bleed pressure down, then shut off the house valve. or just shut off the street. or the house
the_man is offline   Reply With Quote
Whole House Water Treatment Systems HWPipes Plumbing 21 04-25-2013 09:53 PM
I have two water heaters with the pilot shutting off randomly stanlam Plumbing 3 08-14-2010 04:57 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 07:04 AM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 11:36 AM
