Shutting Off Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2010, 09:27 PM   #1
shutting off water
Hello,
I had a plumber over a few months ago to change a vavle. He shut the water off in the basement. He said you have to shut it off and then turn it on in order so that there is no air in the system. Can anyone let me know that order? Also, I have two levers (on the right and left), which one is supposed to be to street and which one to house? Thanks
dwheelie is offline   Reply With Quote
Old 11-09-2010, 09:41 PM   #2
Picky Plumber
I'm sorry, I don't understand the question. Why is there a need to do this? Have you partially drained out your water lines or something? Need more info...
Plumber26 is offline   Reply With Quote
Old 11-10-2010, 06:13 AM   #3
Rewards Points: 1,216
Don't sound right to me usually the air will be pushed right through a system and out the spigots without problems unless he was working with the closed heating system then air could cause some problems. The valve from the street would be the first valve coming through the wall the other valve should be the secondary house shutoff.
COLDIRON is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
