Shut Off Water To Replace Moen Single Shower Handle? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 02:42 PM   #1
Rewards Points: 590
Shut off water to replace Moen single shower handle?
I know that you should generally shut off the water whenever you're working on plumbing-- in case anything breaks-- but my wife just got in a huff because I told her we needed to get to the water shutoff for the shower that's behind a big pile of clothes in the laundry room. Can I replace the handle and twist the stem (the thing was also set up with the hot and cold reversed) without turning off the water? I plan on turning off the water to the house anyway-- just in case-- but again, if it's possible for something to break in here I'll have no water in the entire house until I fix it.
I know that messing with the cartridge would require shutting off the water, but I've heard that is not required with Moen-- just twisting the stem.
I also realize the easy answer is to grab some baskets to get the laundry out of the way. If you agree, then you are being logical and that is not allowed.
operagost is offline   Reply With Quote
Old 03-25-2013, 02:47 PM   #2
Yes.Just don't pull out the c-clip.
plumberman134 is offline   Reply With Quote
Old 03-25-2013, 04:04 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 684
If you pull the clip the water pressure must be off.
You can rotate the stem with the water on and the handle removed
Old 03-25-2013, 08:46 PM   #4
Rewards Points: 590
When you think about it, pretty obvious, right? So I twisted the stem 180 degrees to get it oriented correctly. Worked fine, of course. But the handle didn't, because the Danco replacement-- supposedly for Moen-- used a 1/2" adapter when it needed 1". D'oh.
Old 03-25-2013, 09:07 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Which style of moen is it?
IF it's the posi-temp valve, and the hot/cold are reversed, you WILL NEED to shut off the water, pull the cartridge, and rotate the entire thing.
If it's a moentrol valve, then all you need to do is remove the handle, and stops, and rotate the stem 180*
Journeyman Plumber
Old 03-25-2013, 09:16 PM   #6
MarginallyQualified
Rewards Points: 2,464
Originally Posted by operagost View Post
...but my wife just got in a huff because I told her we needed to get to the water shutoff for the shower that's behind a big pile of clothes in the laundry room.
"No problem honey...
I'll just go down to the basement and shut it off at the main instead."
Old 03-25-2013, 09:34 PM   #7
Rewards Points: 590
... and if the cartridge falls apart, you have no water in the house until it's fixed.
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Replace Toilet water shut off valve knob ifixit Plumbing 5 11-26-2012 09:01 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Plumbing single handle shower zrooster99 Plumbing 5 02-26-2011 09:45 AM
