Shut Off Valves On Cast Iron Radiators - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2008, 08:29 PM   #1
shut off valves on cast iron radiators
I recently purchased a house which has cast iron radiators. I have a few in rooms which are unused (porch and garage). I want to turn these completely off. I turned the shut off valves all the way off, but there is still water coming through and heating the room. I was told that older valves won't close completely. Can I switch to newer valves which will stop all water flow. Thanks.
bdw2677 is offline   Reply With Quote
Old 10-20-2008, 08:32 PM   #2
Whatamess
You can install new brass gate or ball valves.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 10-21-2008, 07:07 PM   #3
Thanks for the reply. I think ball valves would work just right
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 12:07 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
cast-iron radiators won't shut off sonofthetonsured HVAC 13 04-05-2008 09:58 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 05:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
