Old 04-24-2006, 03:58 PM   #1
Shut Off Valves
I have a 30-year-old home, and some of the shut-off valves are stuck...so I couldn't turn off the water if I had to. I'm afraid to use a wrench or something to force it, for fear of breaking it. Is there an easy way to fix these valves?
Coach Gordon is offline   Reply With Quote
Old 04-24-2006, 04:09 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Shut Off Valves
These are probably chrome-plated brass shutoff valves that have frozen open due to corrosion or mineral buildup over time.
You should be able to loosen the handle with a pair of channel-lock pliers. Just grip the whole handle in the channel-lock teeth and turn it clockwise steadily until it loosens. It shouldn't break.
These are probably due for replacement. If they're on copper lines, you can use compression fitting valves without doing any soldering.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-24-2006, 04:13 PM   #3
Shut Off Valves
Thanks Mike! Great info. Gordon
I cannot shut water off. Floorwizard Plumbing 12 06-08-2007 05:05 PM
replacing shut off valves glassman Plumbing 1 03-28-2007 11:26 PM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
Pressure Compensating Shower Valves MikeinBurien Plumbing 4 12-21-2005 11:13 PM
