Shut-off Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2012, 09:20 PM   #1
Shut-off valves
I have a 14 year old house and the hot and cold shut-off valves under the bath room sink won't completely shut off the water. The existing valves are plastic with oval knobs. My question is, is there a better valve that will last longer than the ones I have now?
Dan C1 is offline   Reply With Quote
Old 08-15-2012, 09:54 PM   #2
Rewards Points: 13,300
Post a picture.
Take a look at what color the pipe is. Cheap plastic shut off tells me it just may be Quest tubing.
If it's gray it's quest. Not a good thing. Quest had a ton of class action sutes againt them for leaking valves and bursting pipes.
Old 08-15-2012, 10:30 PM   #3
Originally Posted by joecaption View Post
Post a picture.
The supply pipe is 1/2"copper and the pipe from the valves to the faucets are 3/8" soft copper. I found a brand name of Brass Craft on the valve handle.
Old 08-15-2012, 10:45 PM   #4
1/2 of that is a good thing. How much is sticking out of the wall?
Should be as simple as removing what you have now and replacing with new 1/4 turn Brass craft chrome plated real brass valves and tossing the old copper supply lines in the trash and replace with new stainless steel braded supplys.
Dan C1 (08-15-2012)
Old 08-15-2012, 11:11 PM   #5
Dan,
It's called a 1/4 turn angle stop and looks like this,
VIPlumber is offline   Reply With Quote
Old 08-15-2012, 11:40 PM   #6
Originally Posted by VIPlumber View Post
Dan,
That's it, except mine are straight. I'm questioning the quality of this valve. Should I replace them with the same brand (BrassCraft) or is there something that will do a better job. Why install stops if they won't do what there designed to do (shut off the water).
Old 08-15-2012, 11:43 PM   #7
You said yours are plastic, these are solid brass with chrome plating.
Lots of times valves that have not been shut off for many years are pluged up with trash, or leak at the stem.
If you would post that picture it sure would help.
Old 08-15-2012, 11:55 PM   #8
I don't have a camera. The handles and stems are plastic. I just wanted to know if there is a better valve to use, sense I have to replace them.
Old 08-16-2012, 12:03 AM   #9
Sorry, I meant this one. This valve is being used pretty regularly up here as replacements for the one I showed in the earlier pic, and so far the results have been good.
Old 08-16-2012, 12:11 AM   #10
What is the brand name of this valve?
Old 08-17-2012, 12:07 AM   #11
Brass Craft. Why?
Old 08-17-2012, 12:24 AM   #12
No reason other then that's what my local dealer happens to sell.
Old 08-17-2012, 12:30 AM   #13
Same as me Joe. But I was responding to Dan and wondering why he wants the specific brand name.
Old 08-17-2012, 01:41 AM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 452
Like any brand of a product, Brass Craft makes a cheap model such as plastic stems.
I think the OP is afraid to try brass craft again. But they do make some nice valves- you just need to pay for more for the good product. Avoid the low budget junk from any manufacturer. Same goes for faucets and tools and women....
Replacing shut off valves with broken off handles pcampbell Plumbing 14 08-18-2014 06:10 AM
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
Rainbird Valves Don't Shut Off C_J_GO Landscaping & Lawn Care 8 06-07-2010 08:35 PM
shut off valves on cast iron radiators bdw2677 Plumbing 2 10-21-2008 08:07 PM
Shut Off Valves Coach Gordon Plumbing 2 04-24-2006 04:13 PM
