Shut Off Valve For Washing Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 08:09 AM   #1
shut off valve for washing machine
I have a valve that needs to be replaced because it is spraying water. For now, only way to stop it is by shutting off the main water supply from the basement. Is there another valve that shuts off the water to the washing machine so that I can get water to the rest of the house? Thanks.
xyztrader is offline   Reply With Quote
Old 08-05-2012, 08:17 AM   #2
Rewards Points: 13,968
Most likly not unless someone installed it.
No reason you can not install one now.
Post a picture of the valve that's leaking now. There's lots of other valves avalible that would not be as likly to leak in the future.
Old 08-05-2012, 08:29 AM   #3
Thanks, here is the photo.
shut off valve for washing machine-imag0420.jpg   shut off valve for washing machine-imag0421.jpg
Old 08-05-2012, 08:35 AM   #4
Rewards Points: 582
wow you did not have to rip that up like that...2-screws in back ..remove...lift off valve...install new valve....install 2-screws...done...
Old 08-05-2012, 08:51 AM   #5
thanks, but the problem is that the right side is cracked. as you can see in this photo that it is attached to the water supply line. At this point, I think I will need to call the professional.
shut off valve for washing machine-imag0423.jpg   shut off valve for washing machine-imag0424.jpg
Old 08-05-2012, 08:58 AM   #6
Rewards Points: 582
yep see that ...oh well you win some and loose some..sorry for your trouble but like you said time to call out the big guns....have a good day...ben sr
shut of and drain valve placementin Home Run Heating Vkazman Plumbing 1 02-25-2012 06:54 AM
Help replacing stem valve assembly for washing machine a12733861 Plumbing 7 01-12-2012 11:13 AM
Toilet Water Shut Off Valve anelson Plumbing 1 07-11-2011 09:42 AM
Water valve will not shut off smcpherson Appliances 2 05-18-2011 09:55 PM
location of cold water shut off valve ant2754 Plumbing 2 06-08-2009 08:16 AM
