-   -   shut off valve for washing machine (http://www.diychatroom.com/f7/shut-off-valve-washing-machine-152656/)
xyztrader 08-05-2012 08:09 AM
I have a valve that needs to be replaced because it is spraying water. For now, only way to stop it is by shutting off the main water supply from the basement. Is there another valve that shuts off the water to the washing machine so that I can get water to the rest of the house? Thanks.
joecaption 08-05-2012 08:17 AM
Most likly not unless someone installed it.
No reason you can not install one now.
Post a picture of the valve that's leaking now. There's lots of other valves avalible that would not be as likly to leak in the future.
xyztrader 08-05-2012 08:29 AM
2 Attachment(s)
Thanks, here is the photo.
ben's plumbing 08-05-2012 08:35 AM
wow you did not have to rip that up like that...2-screws in back ..remove...lift off valve...install new valve....install 2-screws...done...
xyztrader 08-05-2012 08:51 AM
2 Attachment(s)
thanks, but the problem is that the right side is cracked. as you can see in this photo that it is attached to the water supply line. At this point, I think I will need to call the professional.
ben's plumbing 08-05-2012 08:58 AM
yep see that ...oh well you win some and loose some..sorry for your trouble but like you said time to call out the big guns....have a good day...ben sr:yes:
