Shut Off Valve Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2011, 09:24 PM   #1
Shut off valve replacement
I've searched through the site looking for similar posts, but mine has a TWIST!!!!
We were in the process of replacing our sink, my girlfriend goes to shut off the water at the valve, and the handle/stem snaped off flush. So my first instinct was to go to shut off the water at main the line. After doing so, I turned off the remaining valve (did NOT break), and then turned the handle on so all the remaining water would drain from the line....
After about a minute the pressure got extremely low but there was still a steady stream coming out, I left for about 5 minutes and no change.
So if the main water shut off doesn't stop the water COMPLETELY, how exactly am I going to change out the broken valve that is under the sink?
All tips and tricks are greatly appreciated!!!!
Picture if available would do wonders too
bates is offline   Reply With Quote
Old 12-03-2011, 09:27 PM   #2
jproffer's Avatar
Rewards Points: 716
It could be water draining from upstairs, if there IS an upstairs...if it truly is the main shut off leaking thru, you'll have to turn the water off at the meter (around here they are outside in the yard).
jproffer is offline   Reply With Quote
Old 12-03-2011, 09:30 PM   #3
Rewards Points: 582
you could try snugging down on main be careful not to break it....if not running to bad you could open lower faucets to see if that lets you repair the valve....you could see if you can compression valve under sink.....again if not running to bad loosen meter nut and let drain into bucket till you fix and hook back up....hope that helps....picture of broken valve would help...
Old 12-03-2011, 09:33 PM   #4
Yes the sink valve that broke is located on the bottom of our split entry. Should I flush the upstairs toilet twice and run all the sinks up stairs?
Old 12-03-2011, 09:39 PM   #5
Rewards Points: 582
are there any faucets below the sink that broke....picture of valve would help...if there are lower faucets open them...
Old 12-03-2011, 10:00 PM   #6
Total downstairs (where valve broke), there is the shower, the sink, and the toilet. Upstairs there is the kitchen sink, bathroom sink, toilet, and shower.
Old 12-03-2011, 10:10 PM   #7
Rewards Points: 582
if you shut off main line yes open up faucets to see if you can repair valve or replace it.....again picture would help..
The Following User Says Thank You to ben's plumbing For This Useful Post:
bates (12-03-2011)
Old 12-03-2011, 10:19 PM   #8
I'll get a picture of some time in the morning. The valve replacement will have to wait until then, seeing as all the shop are closed!
Thanks for all your help!
shut off valve replacement garrettv Plumbing 1 04-24-2011 12:23 PM
Replacing shut off valve and I can't get it off. Any ideas? davidevan Plumbing 9 01-23-2011 01:15 PM
Broke shut off valve? rmartin66 Plumbing 2 09-12-2010 12:01 PM
repairng Watts laundry room shut off valve RoyGBiv Plumbing 1 08-28-2010 01:16 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
