Shut Off Valve Installation - Different Fittings Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2011, 10:57 PM   #1
Rewards Points: 518
Shut off valve installation - different fittings issue
I went to install a new faucet just to discover that the builder did not put in any shutoff valves! The faucet has 3/8" end and the PEX pipe coming up is labeled 1/2" and the fitting appears to be a 1/2" fitting as well so I went out and bought a 3/8" to 1/2" shut off valve and attempted to install it. The 3/8" end went on fine and has finer threads but I could not get the 1/2" end to go on as the threads are completely different(fitting crimped on the PEX has very few larger threads) and it started to cross thread.
I don't know my plumbing terms and fittings but I know I have two different types of fittings of the same diameter. Is there a shutoff valve that will have the right ends on both or should I change the fittings currently installed in the PEX?
n0c7 is offline   Reply With Quote
Old 12-31-2011, 11:00 PM   #2
A picture of what you took out of the brass/pex would be helpful to me
broox is offline   Reply With Quote
Old 12-31-2011, 11:03 PM   #3
Rewards Points: 518
Here's a pic of the old faucet which is what used to be connected to the fittings inside the PEX.
Old 12-31-2011, 11:06 PM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by n0c7 View Post
...to discover that the builder did not put in any shutoff valves!
The faucet has 3/8" end and the PEX pipe coming up...
What is at the OTHER end of that PEX line?
(point is that no valves is VERY unusual)
I don't know my plumbing terms and fittings...
The basics: IPS / Copper / Compression / FLARE
In your picture I believe I see three of these four options.
Some more reading
The Following User Says Thank You to TarheelTerp For This Useful Post:
n0c7 (01-01-2012)
Old 12-31-2011, 11:07 PM   #5
That looks like half inch male iron pipe threads. You will probably have to get short half inch nipples(threaded pieces of pipe) and half inch female thread by 3/8 compression thread valves.
The Following User Says Thank You to broox For This Useful Post:
n0c7 (01-01-2012)
Old 12-31-2011, 11:10 PM   #6
Rewards Points: 518
Some more reading
Just posted a pic of what was at the other end.
Old 12-31-2011, 11:11 PM   #7
Rewards Points: 518
Ok so what actually converts the iron pipe threads to compression?
Old 12-31-2011, 11:30 PM   #8
Rewards Points: 518
So I just re read your answer and I guessing you mean I need to find a 1/2" NPT to 3/8" compression(not sure of acronym)?
Old 01-01-2012, 07:02 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Yes.......
The Following User Says Thank You to Bondo For This Useful Post:
n0c7 (01-01-2012)
Old 01-01-2012, 07:45 AM   #10
Civil Engineer
Rewards Points: 4,530
Alternatively you can purchase a PEX shut off valve that has compression on one end, and half inch PEX connection on the other. I have three or four of them in my house. By the way, that looks like Wirsbo expansion couplings on your PEX, you need a special tool to install that kind of fitting, but if you cut off the pipe below the ring you can use alternative types of connections.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
ben's plumbing (01-01-2012), n0c7 (01-01-2012)
Old 01-01-2012, 05:16 PM   #11
Rewards Points: 518
Thanks for all the info. I've successfully installed the new faucet using a short extension with the proper valve as mentioned above. Also spent time reading about the types of threads out there to familiarize myself since I wasn't aware there was so many types! Guess I was just lucky in my past small jobs that I had the right fittings.
Old 01-01-2012, 05:17 PM   #12
Rewards Points: 518
Yup wirsbo. Thanks for the alternative options.
Old 01-01-2012, 10:36 PM   #13
Rewards Points: 518
Forgot to ask another amateur question - inside the fittings crimped onto the pex were black rubber washers probably left over from the old faucet. They were corroding and did not fit well with the new nipples. I removed the washers and used Teflon tape. Is this ok long term?
Old 01-02-2012, 12:51 AM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 358
The black washers worked like the washers in a garden hose. They are part of the pex x fip fittings. If they are not leaking now then i wouldn't worry
Old 01-02-2012, 01:09 AM   #15
Rewards Points: 518
Ok. The HD helper told me that if they were corroded that I could remove them and use Teflon or pipe dope as I would have to buy a new fitting just for the washers. Just want to make sure this will last over the years. No signs of leaks yet.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 05:43 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 04:34 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
