Shut Of And Drain Valve Placementin Home Run Heating - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 12:47 AM   #1
shut of and drain valve placementin Home Run Heating
Hello,
I have a Home Run 2 zone heating system installed. I am adding the 3-rd zone.
On each return line in each loop Contractors put shut off valves. There is only one Drain valve for the whole system.
If I am correct, currently there is no way to drain each loop,only all together. Also I do not think I can isolate a particular loop in case of a problem with the loop since I only have shut off valves on return lines.
Since I am going to install the 3-rd zone, I would like to make it correct.
What should I do in order to have:
Ability to drain each loop separately
Ability to isolate each loop
Should I install shut off /ball valve on return and supply line on each loop and Drain valve on return line of each loop?
Thank you,
Vad
Vkazman is offline   Reply With Quote
Old 02-25-2012, 06:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,410
Ayuh,.... If that's what ya want, then Yes, do it while ya got it drained....
In the system I built last year,...
I put in isolation valves, to isolate the loops,...
But, the whole system still drains from the boiler...
low-pressure drain valve fwes Plumbing 0 10-02-2010 07:57 AM
Hot Water Heater Drain Valve Mitch125 Plumbing 4 09-28-2010 12:07 PM
Sewage smell from pressure relief valve drain daveh20 Plumbing 2 10-09-2009 10:45 AM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 04:30 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
